Johnson / Evinrude 9.9 / 15 HP Connecting Rod Torque
BigB9000
This is for a 1977 9.9 HP, with a 1975 15 HP power head, using a 1978 Manual specs.
Manual lists it at 48-60 Inch pounds.
This seems a little low?
Can someone verify the correct settings?
Also, should I use thread locker or anything on them?
Im talking about these guys:
Re: Johnson / Evinrude 9.9 / 15 HP Connecting Rod Torque
It is correct.
Bosunsmate
New screws shouldnt take threadlocker, if you were using the old ones i would use a bit of threadlocker but ive never reused old screws as they will be slightly deformed.
