i posted on here about my 1970 johnson 18 hp motor and for just a quick recap, when i got this motor i ran it and found that it didnt want to idle and seemed to bogg on top end. other then that it ran good. the person i bought it from told me it was the fuel pump. after reading everyones advice i purchased a fuel pump and carb kit. well it came today and i installed the fuel pump first just to see if it made any differance. it fired right up and seemd to idle better. i let it warm up and goosed the throttle and it also seemed to wind out better. after about a minute, it began to kick back, i guess misfire. not all together, just like every once and while, and then died. so i pulled the spark plug wires loose to check the spark. something wierd kinda happened. i got it started and pulled one wire off, as soon as i did it quite like it was only firing on one cylender. after i started it again, both wire seemed to have good spark and both ran with the other unplugged. i ran it a little longer and it began to kick back again. now it runs better as far as idle and top end but this misfire thing has thrown me. not sure where to go from here. i do still have the carb kit and plan on installing it. any info would be great.
