Johnson/Elto 22HP Need Help
jonsilva
I just picked up an Elto motor, for some reason it has a Johnson cowling on it, The model number is #22D10E and the serial number is # 19132. I am trying to find out if it is and Elto or a Johnson and what year it is. Any information would be great. i am planing on fixing it up and using it. elto.JPG
Chinewalker
It may be an Elto clamp bracket and lower end, but the powerhead will have needed some significant mods to take the Johnson cowling. Double check the number on the expansion plug on the cylinder block for the numbers there. Not out of the question for someone to have swapped some parts around over the last 60 years. What color is the cylinder block?
jonsilva
here are some more pics, what should the number on the plug be?
Chinewalker
The forward brackets have been changed out to Johnson style brackets, and the rear brackets were removed from the head. Rest of the powerhead looks like Elto, as it had a fuel pump (BEFORE the Johnsons and Evinrudes!) Does it have the Johnson face plate to fill the hole in the front?
F_R
Honorary Supreme Mariner
Looks like it might be an Elto. The model / serial number core plug is beside the rear mounting bolt for the recoil starter in your first picture. See if that matches the numbers on the brackets. The 22hp Gale/Elto and 25hp Evinrude and Johnson motors are very similar. The main difference is the cylinder bore size is smaller on the 22.
jonsilva
The guy I bought it from says it ran the last time they put it away, 5 years ago. Is there anything special I should do before trying to start it? All the fuel lines look like new and everything looks really clean.
F_R
Try it and see if it runs. You may be lucky. But even if it runs and pumps, don't take it out until you replace the water pump impeller. It will let you down if you don't. Also, unless they have already been replaced, expect the ignition coils to be bad. On the other hand, since it was running five years ago, they probably have been replaced. As I said, try it before fixing anything.
oldboat1
It looks like a nice motor, well kept. If into restoration, you might look for a Gale hood (or Bucaneer, Viking, Goodyear, Sea King etc etc) -- thinking you can get Elto decals from a few sources.
