Johnson elektromatic 40 hp 1968
Kongblom
hello my name is nikolaj. I have a johnson elektromatik 40 hp 1968 I have a few problems with it. it starts fine, when I put it in forward gear and full throttle. it will stay in the low revs, but once in a while all of a sudden full revs in small increments ... the strange thing is that it may well take full throttle neutral .. when you put it in reverse rising revs, but it does not always go in reverse..
Honorary Supreme Mariner
Check for strong spark ( must jump 1/4" or 1 cm with ease ) on that motor.--------Pull the flywheel and check the coils.--Use a puller and the 3 threaded holes to get the flywheel off.---Sounds like the motor is only running on one cylinder at times.
F_R
Agreed, it is running on one cylinder, with the other one occasionally kicking in. When it kicks in, it goes faster. You have an ignition problem, nothing to do with the Electramatic.
HOWEVER, sometimes not going into reverse is an Electramatic issue. Possibly a bad shift switch in the control, or a wiring problem. When is the last time you changed the oil and are you using the correct oil?
BTW, I am wondering how you are going about getting full throttle in neutral? Nevermind, don't be doing that unless you want to scatter engine parts all over the area.
Kongblom
thank you very much .. I have wondered if it could be the ignition .. I have fortunately a new set of coils .. :) I do not know when the gear oil was last changed since I just got it .. I better get The oil changed. what type of gear box olie do i use.?
You need the correct oil.---------Usually called TYPE -C here or now BRP product called " premium blend "
