Johnson electromatic 40 hp 1969
Kongblom
Hi I'm testing for sparks on my Johnson eletromatic 40 hp 1969.
Do I need to hookup the motor to the battery and key switch to get a spark..??
Ad the moment I tried, just pulling out the spark plugs an turning the flywheel by hand, while holding the spark plug to
Ground..!
Joe Reeves
To check for spark, you DO NOT need the battery hooked up... BUT... you need a spark tester whereas you can st a gap of 1/4" for the spark to jump... available at most automotive part stores. The flywheel must be turned fast via a pull rope. You cannot use a spark plug to test the spark nor can you turn the flywheel by hand to produce a spark.
boobie
You can buy spark testers at parts houses for around $8.00.
