Good morning, I have been doing a bit of research before I posted this so hopefully I didn't miss a post. Short story is I have a 76 Johnson 85HP that I got running after rebuilding the carbs. I checked the water flow and found it needs an impeller. While I was waiting to purchase the impeller, I came across and bought a 81 Johnson 140 with low compression on one cylinder for $200. Everything I read said the motors were almost the same and it had a bunch of new parts and power tilt... so a good parts motor.
Now when I pulled the outdrive off the 85, I found a lot of oil, almost like the top seal went out. So...
1. Can I put the 140 outdrive on the 85 and is the gear ratio the same (all seals just changed, new gear oil and new impeller)
2. Can I put the 140 carbs, stuffers and bubbleback exhaust on the 85 or are the exhaust ports too restrictive?
The previous owner of the 140 said that he thinks the ring on the low cylinder broke because you can't see any damage or metal in that hole. The only thing that keeps me from looking at this direction is the Tiderunner is rated for 115HP max.
I'd appreciate any help or sources of information you guys have!
Chris
Chris
