Johnson charging
Kerry58
Hello I'm new here and just recently purchased a Johnson 40EL71B outboard I have a few questions I hope someone on here will be able to answer .First one what are the proper spark plugs to use , gas ,oil ratio . and does this motor have charging capability . Motor is a Johnson 40EL71B . I don't know anything about this motor other than it runs strong . Thank You
Vic.S
40 Hp, Electric start, long shaft, 1971
Currently recommended plugs are Champion J4C gapped at 0.030" although would originally have been fitted with J4J ( now obsolete) or possibly AC m42k.
50:1 fuel mix
No charging facility as standard. ( Dont know if a belt driven generator kit could be fitted)
Points ignition so if you have any ignition related problems inspect coils and clean / reset or replace points/ condensers
gm280
:welcome: Kerry58 to iboats. Glad you joined us here...
I would certainly suggest you buy a factory, HP, Model and year specific shop manual for your engine and you will have all the info for your engine you could ever want to know. Those factory manuals are the "gospel" on that engine. Don't buy an after market manual because they try to cover too broad of a range and therefore don't go into the fine details of how your engine works and the little details you won't get form such manuals... Just a good suggestion...
Kerry58
Hello GM280 Thanks for the info also , I have a question in regards to something you wrote " A gospel on that engine" ( is this engine a problem child of sort ) .
kbait
He meant gospel as 'Divine word' - not Godsend as in 'thank God I have this detailed manual for this pile of junk. 😀
You have a nice, reliable motor.
