Johnson '93 150 hp powerpack
dennis352
Re: Johnson '93 150 hp powerpack
I just had to replace my powerpack and reg/rec. I was told it could have been caused by connecting the battery cables backwards or using jumper cables that were connected incorrectly.
coventina
thanks dennis352. <br />are there any other causes you can think of - or may have come across - that lead to a failure of the powerpack? can corrosion affect its circuits for example? can you tell me how much did you pay for it (new or used)?
clanton
Bad ground, charge coil output too high. If it is a 60 degree looper, sometimes phases of the moon changing. The 60 degree looper also needs OEM spark plugs and wires.
coventina
thanks for the reply clanton. If the pack is so sensitive then I guess it is a miracle that it lasted for all these years (more than four years with me, and probably six years with the previous owner).
dennis352
I purchased my powerpack new through my brothers shop so i got it at cost. He has said that im welcome to send anyone from here in need of electrical parts his way and he would take care of them. We live in Fl so you would have to pay for shipping but im sure it would still be cheaper than buying it at your local boathouse. I was surprised at the mark up in marine parts. He only sells CDI parts but if you are interestred or anyone else that reads this , your welcome to emai me mcclearydm at earthlink.net.
clanton
OEM packs come with new timing sensor, Inot sure about the CDI. I always change sensor same time and verify timing with timing light. The OEM sensor testing method will not always reveal a defective sensor.
