Johnson 90 spl
Diverduck
Ok. I have a johnson 90 spl. I've had it for a year or so and it has always ran great. A little cold natured but runs well. Have been running it every weekend with no problems. Launched thursday ran 20 miles..no problems...Friday ran 10 miles..no problem..saturday launched and rode out from launch. Idled up to warm up motor. Idled fine for 5 minutes. Went to take off and it died. Hasn't started back since. Im getting spark on all 4 plugs. Gething gas to carbs. Pulled carbs and inspected even though it had been running fine. Unhooked gas line from boat and mixed up smalll 1 gallon can to rule out bad gas. It will bust off every now and then but only for 1/2 a second or so. Compression is good on all cylinders. Ohmed out stator at 1.7. I don't know where to go from here. What to check. Any help would be extremely appreciated.
Honorary Supreme Mariner
It is up to you to do some checking.---------Remove flywheel and inspect the key.-------You also need to attach numbers to the compression values and the spark.----Such as the spark jumps an air gap of 7/16" or more.
Diverduck
Compression was 110 on all cylinders. I used an online spark checker to check spark. I'll pull flywheel tomorrow.
batman99
Good engine / Piston PSI? re: > 100 PSI and within 10% of each other.
Good / fresh gas (at proper mixture)?
Good gas flow (re: hard squeeze bubble) and pump appears to work properly?
Good spark and timing hasn't changed?
Carbs inspected / cleaned?
Good engine pressure test (to test crank shaft seals)
If all above checks out, I'd remove its reed cage and inspect its reed leafs. Broken reed leafs are rare but do happen.
emdsapmgr
Racer one is correct, if the flywheel key shears, the flywheel will get out of time on the crank and it won't start. A good place to start your testing!
