I recently bought an angler 17 foot center console boat with a johnson 90 hp v4 outboard. I took the boat out one weekend and everything was fine. The following weekend i took it out again and when i went to get on plane the motor started sputtering at 3000 rpm. I stopped and pulled the plugs and i found water on the bottom port side cylinder. I changed both head gaskets and exhaust plate gaskets and im still getting water in that cylinder.
