Johnson 9.9hp JR10RCRA 1984 Fuel Pump?
henry2008
Hi, question for the techs :)
I need some help,when I pull the choke, my motor runs great but when I stop the choke my motor dies. Any Ideas??? I'm guessing the fuel pump but I'm not sure!
Vic.S
Re: Johnson 9.9hp JR10RCRA 1984 Fuel Pump?
Almost 100% certain it needs a carb clean. If it was the fuel pump you would be able to keep it going by pumping the priming bulb.
henry2008
So you think the fuel pump it's ok?
Any links on how to clean a carb? Thanks for your help
henry2008
I'm a rookie can you tell me where is the priming bulb located?
henry2008
You know what? I used the slow speed adjust knob and it didn't work.
I did the Idle speed knob with no results too.
henry2008
Thanks for your help. I search and I found some topics regarding this problem. Probably a blocked jet from carburetor, so I'll let you guys know :)
Vic.S
the rubber bulb in the fuel line between the tank and the engine, the bit you squeeze to prime the fuel system.
#8 IN THIS DIAGRAM
Yes I'd agree almost certainly the slow speed jet blocked, but if it is you should be able to get the motor to run at high speed but die as soon as you return to idle. If you have messed with the slow running adjustment try sorting that out first.
henry2008
Hey Vic Thanks. My motor is running again! I cleaned the carb :)
I still have a little problem with the gas it goes down a bit no too much
( Probably the fuel pump) but i used the priming bulb and still ok.
You guys rock!
Vic.S
sorry I dont understand.
henry2008
Hi Vic, Problems solved, yes 2 problems found :)
1- Carb (Cleaning solved the problem of starting the motor)
2- Fuel Pump(Replacing solved the problem of killing the motor at full speed)
Plus such a wonderful search option you have in the forum helped me to test the fuel pump simple and easy.
+ teach me how to start my motor when cold.(2 or 3 pulls)Took me 10+ Before the search.
Now my motor is good and running !!!
Thanks to all
