salmon sam
- Aug 18, 2008
- 5
I have a Johnson Seahorse 9.9 (probably a late 70's model). Model
#J10RLCOM, Serial #E6038505. It starts and runs well but there is very little water exiting from the cooling water discharge (pea hole) and it is very hot so I am concerned about some kind of blockage in the cooling system. A friend suggested I check the impeller assembly in the lower shaft. I am trying to access the impeller housing and have separated the shaft at each of two points but cannot access the bolts holding the impeller housing to the lower shaft housing. Any suggestions? Do I need to separate the entire shaft from below the powerhead housing? Am I on the right track? Are there any online diagrams I can refer to to get a better idea of what I need to do? Thanks for any help you can give.
