Johnson 9.9 running problem have to feather choke
Buckeyesnookhunter
I have a 1998 9.9 johnson it has sat for a year when I went to start it this year it started up ran for a few seconds and died. the only way I can keep it running is to feather the choke but once the choke is pushed in the motor cuts out,
jimmbo
Welcome to iboats
Well it does sound like a lean condition. Are you able to get the engine to run at higher speeds without the choke? When the engine was put into storage, was fuel stabilizer added to the gas? Did it run fine prior to storage? A thorough cleaning of the fuel system may be needed.
Stumpalump
Rev it up and choke it with your hand to create a high vacuum. Sometimes this will be enough to pull the jelly sludge thru the carb. If no then pull the idle adjust fuel screew out after you count the turns in. Spray carb cleaner or aresol sea foam in the hole to clean it. Still no then rebuild carb. Start with clean gas can and lines.
Buckeyesnookhunter
jimmbo Well it does sound like a lean condition. Are you able to get the engine to run at higher speeds without the choke? When the engine was put into storage, was fuel stabilizer added to the gas? Did it run fine prior to storage? A thorough cleaning of the fuel system may be needed.
I hope I am Replying properly yes on the higher speed yes on fuel stabilizer and yes on running fine prior to storage
Buckeyesnookhunter
Stumpalump Rev it up and choke it with your hand to create a high vacuum. Sometimes this will be enough to pull the jelly sludge thru the carb. If no then pull the idle adjust fuel screew out after you count the turns in. Spray carb cleaner or aresol sea foam in the hole to clean it. Still no then rebuild carb. Start with clean gas can and lines.
Thank you a friend said bad gas so I'm going to try fresh gas again and hope thats all it is.
arctic_dan
In my experience gas is rarely the problem. Start with the basics. Remove & clean the the carburetor, Adjust carb, check fuel lines for cracks/leaks, If this fails, you can check the pump to see if its contents are not dried out and not functioning properly.
