Johnson 9.9 model year?
Mtnmax
I recently bought a 9.9 hp Johnson outboard. The transom mount had been replaced and the serial number is no longer there. How do I go about finding out what year this engine is so I can order parts?
robstead
I would look around inside the motor, usually on some important parts there will be numbers on them. You can look up OMC followed by the part number of say the carb and you'll get an idea of the years. On the other hand, posting pictures could be helpful to some.
Mtnmax
Here are some pics
robstead
Could be anywhere between 1974-1990, if you look around near flywheel towards the stern there should be a small metal freeze there should be numbers stamped on there as well.
roscoe
approximately early 1990's.
Model number should be on the welsh plug/freeze plug, small aluminum disk on side of block
