Johnson 9.9 4-Stroke Water pump bolts torque?
Johnalcon
I have a 2003 Johnson 9.9 four stroke, model J10TBL4ST. I would like to know the correct bolt torque spec for the four water pump housing bolts and the torque for the 4 bolts that hold the lower unit to the exhaust housing. I have replaced the water pump and am now on my way back together. Thank You for your help.
bankerjohn
Re: Johnson 9.9 4-Stroke Water pump bolt torque
According to the OEM manual for my 1996 9.9 4-stroke, here are the torques:
Water pump housing (4 screws) - 60-84 in. lbs.
Gearcase (6 screws) - 96-120 in. lbs.
I imagine they would be the same for a 2001 model.
Johnalcon
Re: Johnson 9.9 4-Stroke Water pump bolts torque?
Probably not the same but maybe close to the same. Mine is a 2003, Suzuki manufactured Johnson, with 4 water pump housing bolts and 4 gearcase bolts. Thanks anyway.
