Johnson 9.9 1982 model siezed throttle rod
something_wrong
Hi
I have a 9.9 Johnson 1982 model and the throttle rod has seized, The tiller handle,the rod in the tiller handle are both fine its the rod that goes into the cowling.
Once i remove the tiller handle how do i get the rod out of the engine is there a locking pin / nut or something, I have ordered a manual but it wont be here for a week, so was looking for any help.
cheers
Jeff
AlTn
Re: Johnson 9.9 1982 model siezed throttle rod
marineengine.com...your engine..exhaust housing...part #80...if you can work from the parts diagram you'll see what has to come apart
something_wrong
Thanks very much
Great it looks like item #53 is the shaft which is seized on my engine and the rest looks simple enough
Cheers
Jeff
something_wrong
Hi AITn
Is there any special way to remove the bush #81 on the drawing, I have removed the, Gear pin & Gear, circlip and washer and the complete tiller handle,
I managed to get a pair of vice grips on the bush and turn it slightly trying to ease it out without breaking it, but it is stuck fast I assume from the shape if has to come out through the front?
When i twist the bush the shaft turns the other gears inside which control the throttle, i gues it is bush #81 which is seized stopping the throttle from turning.
AlTn
k..to be on the same page...part's 52,80,83,107,108,109 have been removed and shaft #53 and bushing #81 remain?
something_wrong
I Think i have it sorted now
I applied intermittent heat to the housing around #81 and was able to twist and pull it slowly out.
The numbers u listed were still in but now i should be able to get them out with a little intermittent heat and some lube on the other bush #52.
AlTn
k..good deal..though they have 2 small "bumps" and 2 notches to fit into, I'd go ahead and put a witness mark on gears #52 and #109 before you take them off the shafts, it might take some of the "frustration" out of realigning them during reassembly
