Johnson 9 .5 1969 Outboard problem
Hoppyfishin
Hello, I have a Johnson 1969 9 1/2 hp outboard motor. It runs fine with throttle all the way pulled out and in Neutral but as soon as I give it a rev it dies. I took it out on the lake after sitting in my garage for the winter and It worked fine for about 2 hours. I still have the metal tank (which I bought a new pmastic tank and fitting for it) the valve is fully open on the tank and no leaks. I recieved the motor from a guy that took good care of it The year before it ran just fine. Im thinking since i didnt do anything to the motor when I put it in the garage for the winter I may have done something to it. I am very new to all this.
Honorary Supreme Mariner
?---It runs fine wjth the " choke pulled out " perhaps ?----That clearly indicates you need to look at the carburetor.----Those motor will run on one cylinder.----First thing to do is pull the flywheel to look at the coils.---They either are new replacements or it needs a set.
Hoppyfishin
Im sorry it only starts with the choke pulled all the way out. Once I push the choke in at all it will putt out, or once I rev it with the throttle handle it will putt out (with choke fully pulled out) so ecen when I put it in forward or reverse and give it a turn of the throttle it putts out. Im sorry if im not explaining this well I have no experience with this
Crosbyman
careful with the carb........ better read up on leroy's caution about one screw hard to reach ....
A TIP HERE,​
when you get that flathead screw loose, it is best to reach in under the timing plate and use a 4 fingered pickup tool to retrieve the screw before it falls down between the actual exhaust housing and the outer shell
read the article for carb service ..:)
http://www.leeroysramblings.com/OMC_9.5.htm​
Hoppyfishin
Ok the carb will only fill with gas that I pump in, thats what the motor runs on, then dies, If I keep pumping gas the motor still runs, I changed the float, needle and gasket on the top half. Will cleaning the bottom part help the motor suck more gas?
The diaphragm to repair the pump is about $4.00 and yes it is available as a spare part at a BRP / Evinrude / Johnson dealer.
