Sol Searching
- May 30, 2008
- 16
I've got a 2000 Johnson 6 horse (used 5 times) that I put a new 8 horse carb on (I was told that the only diff. between the 6 and the 8hp is the carb.) I mounted it on a 8.5' inflatable(110lbs.). With myself (220lbs)and my wife (115lbs) in the boat. The boat wouldn't even get up on a plane, it just plowed water. I even had my wife step out and I went on my own and the same thing happened. I sounds like it is reaching full throttle and I even took the helmet off and "floored" it manually and still BLAH! I would think that a boat that small with 8hp would fly, am I wrong or is there something I am missing? P.S., I never used the motor on the boat with the six hp carb.
