Johnson 88 SPL not firing up, makes clicking noise
BassBoatNewbie
Just recently got my first Bass Boat which has a Johnson 88 SPL on it. After having to rewire the ignition I go to put the battery on & messed up by putting the cables on backwards (Stupid mistake I know). After a spark show I took the cables off for a few mins then tried again, putting them on correctly this time. I went to fire the motor and got nothing except a Clicking noise. I've messed around checking voltage & everything seems to be working properly I just can't get the motor to fire up. I noticed it was really low on gas as well afterwords. Would that explain my Clicking noise? I'm brand new to this stuff so bare with me.
emdsapmgr
It is typical for the start solenoid to make a click noise, when the key switch is turned to the "start" position. Possible the contacts inside your solenoid may be burned (with age) and it may need to be replaced. Also, when the wires were connected backwards, the rectifier probably got fried, too.
emdsapmgr
Cheapest thing to do is replace the solenoid and see if you can get it to crank and start. Once running, you can determine/test if you have any charging voltage output.
