Lil' Johnson
- Jul 13, 2008
- 36
I have a 1988 Johnson 88 SPL. I recently purchased the boat and motor. Before I put the boat in the water, I replaced the water pump with a full kit, and the complete stern bracket assembly with TNT because the original was rusted to the point of no return. The first time out, one of the carbs got trash in it, so I cleaned both carbs. Since then I have used the boat about 6 times, approx 4 hrs each time with no problems. Yesterday I went into the bay and ran aground for about 20 yards. I didn't ever ground the boat or stop moving forward. By the time I realized the motor was slogging mud and I started to trim up the motor, I was through it. Right after that the overtemp horn went off. I ran a short distance(maybe 45 seconds) and beached the boat on the bank of the canal. I let the motor cool for about 10-15 mins after the horn stopped and started it up and headed for the dock.(the motor was hot when I stopped, It was definately overheating) After only going a short distance at full throttle(maybe 3/8 mile) the horn sounded again. I beached the boat again and waited for the horn to stop. The next time I started it up and just idled down the canal, it never got hot. I idled for about 3 miles and never got hot. As soon as i was about 1 mile from dock, I opened it up again. Overheat horn immediately. waited for horn to stop and idled back to dock. After the boat was home, ran it on muffs for 1/2 hour and never even close to hot. What could the mud have done to my motor? The telltale stream is good under all engine loads and RPM's. The motor is and always has been operated in saltwater.
