handyman guy
Thread starter- Joined
- Jul 22, 2017
- 4
Put boat on lake, started up ran for about 5 minutes at full throttle. Throttled back, put in neutral to pull up to dock and engine died and now it will not start. Starting fluid does nothing with carburetor removed spraying fluid directly into intake manifold. Checked all four spark plugs, excellent spark. Removed flywheel to check key, seems to be in good shape. Checked compression between all four pistons - running between 57-68 psi. Also, checked the leaf valves and they seem to be working correctly. Any thoughts or ideas would be greatly appreciated as I have run out of ideas. Johnson #85ESL72
