I just purchased a 1969 Johnson 85 HP model #85ESL69M that supposedly ran. Upon trying to start it, I discovered it has no spark to the plugs. I pulled the flywheel and the points look great. The 2 wires that run down to the Amplifier from the points had rotten insulation and were bare in many places causing them to touch each other so I replaced them with new wires. This did not help the no spark problem. The amplifier has power to it on the purple wire, but I can not get a reading leaving it except a small amount of voltage that runs up the black wire to the points ( This wire is the only wire with a spade terminal end and quick disconnect) There is a blue wire that connects to the coil but no power there at all? Even while cranking the engine over. I believe that makes the amplifier the problem, but how can I test the amplifier to make sure it is the problem? They are very costly, and I don't need a spare if mine is OK. Any other thoughts / suggested tests, will be greatly appreciated. Thanks so much, Dave
