Johnson 85 hp 1979 v4 loses power when warm
colewhitmore41
My outboard runs best always when cold right after launched then loses power after it warms up. I have narrowed it down to one or sometimes two cylinders not firing. It still gets on plane with 3 but will not when running on two. Could it be a bad power pack since when it is running on two cylinders the two that will not fire are on the same bank of cylinders.
colewhitmore41
I replaced one but it still has problems with dropping one or even two cylinders when it gets warm
interalian
You can swap the power packs and see if when you have failure the dead cylinder(s) move to the other side. I always like to prove the failure before throwing parts at it - gets expensive fast.
emdsapmgr
Older engines wind up with older ignition components. Older ignition components become affected by heat. And that can be just the normal temp the engine runs at. Not an overheat. So, any engine which runs fine when cold, but craps out when running at "normal" engine temps may have some bad ignition component. So, next time this happens, make sure you have spark on all 4 spark plug wires. The prime suspects would be either power pack, the timer base or the stator. You can swap the power packs- if the lack of spark goes to the other head, that test will tell you something.
