Johnson 85 120hp running rough at low speed
jeftfm
Hi - my 1985 Johnson 120 is running a bit rough at low speed, revs change a bit at mid-speed and it stalls when shifting gear. It feels like one cylinder is not 100% - is that a possibility? I'm about to try a few things and just wondering if there's any suggestions here about my sequence of checks and if there are other things I could check.
I plan to : 1. check and clean plugs 2. clean fuel filter 3. check fuel lines 4. adjust idle speed. 5. Drain and clean carb bowls. Anything else I should check? Other suggestions? Thanks
Forgot to mention - spark plugs were changed 6 months ago. WOT runs good.
