Hi,<br /><br />I am in the process of replacing the gear shift control cable on my 1979 Johnson outboard. I have the control apart but am having trouble getting the cable out. I have removed the Allen screw from the centre of the plastic cam disk but the disk or the shifter handle will not come out.<br /><br />Is there some trick to this as I would have expected that the allen screw held the plastic disk on to the shifter handle.<br /><br />I need to remove this disk before the control cable can be removed.<br /><br />Any help with this would be appreciated.<br /><br />If someone has an email address I can send a photo of the part that I am referring to that explains the situation.<br /><br />Thanks in advance.<br /><br />Tony.
