Johnson 75 HP starting prob
Cpt Drydock
HELP!!!! I bought a boat with a 75HP and no spark. I was wondering where to find a good wiring diagram and also wiring harness for this 1962 engine. Model # V4AL 14L
Chris1956
Re: Johnson 75 HP starting prob
Cpt. I would invest in a service manual, especially if you haven't worked on outbaords before. Your library may have the manual for check out.<br /><br />Your motor has two sets of points and one condenser, under the distributor pulley. Removal of the pulley cover will expose these. Clean and gap both sets of points to .020 in. The second set of points needs to be set with the pulley turned 180 degrees away from the first set. There are faint timing marks to do this. Disconnect the killer wire on the side of the distributor and spin the distributor to check for spark. Id there is still none, suspect a cracked coil or a bad condenser.
