fromtheriviera
- May 27, 2009
- 23
Re: Johnson 75 hp Slow to pick up power
Tachometer: I think I would rather mount a permanent lowest budget tachometer because I live in france want to avoid shipping charges from US or UK. I have located the 3 pin wires ready to adapt. .
Can you recommend a standard low budget US model / make that would suit my motor then I will try to see if I can buy locally in a marine merchant. Thanks chinewalker for your comments I will keep in mind that the motor is rare. That all the more reason I would like to invest a bit in it to keep it running for a few more years then.
Water impeller change: I guess this means having it serviced then ? I have changed the lower unit oil but was hoping to avoid servicing the engine this year. In south of france everything is 400% more expensive and the mechanics are not friendly in the least. I will ask for a quote.
Solenoid Primer: Will leave it like this as don't use the boat in winter and here the temperature is prety mild all year round.
Missing housing:
I am looking for second hand exhaust housing as my motor did not have these parts when I bought it.
http://www.boats.net/parts/search/BRP/JOHNSON/1988/J75ECCA 1988/MIDSECTION/parts.html
44 0206006
COVER, Exhaust housing, rear
45 0330373
COVER, Exhaust housing, front
46 0320211
EXHAUST HOUSING, Outer
50 0314024
SEAL, Outer housing
Missing housing:
44 0206006
45 0330373
46 0320211
50 0314024
SEAL, Outer housing
