Johnson 70 Problems
Allan B
Hi Im running a johnson Model J-70TLCNB when i open up the throttle it starts out fine then cuts out After checking wiring /etc ive eliminated it down too the bottom plug has no spark when i check it Have put in new plugs/ Wires still same problem some days it will almost run all day with no troubles and the next day i barely get away from the dock and it cuts out Could this be a coil problem. I live on the flatlands of alberta ,canada and a boat mechanic is a long way away,never mind a good lake will greatly appreciate any help Thank you Allan
D
DJ
Guest
Re: Johnson 70 Problems
Allan,<br /><br />Switch the coil from a cylinder that is not giving you trouble and see if the problem moves.
The Marine Doctor
Allan..when this problem happens...what are the symptoms on the spark plug.<br /><br />TMD
Allan B
Ok never thought of switching coils good idea!!! and Marine dr i don't understand what u mean by symptoms ?? Gonna have too make a trip back too a lake too do the coil thing<br /> Thanks Allan
