Johnson 70 motor help needed
jwolfe3
I recently purchased a Starcraft 1700 that has a Johnson 70 Seahorse motor on it. The boat and motor have been setting outside for a few years unused. I tried starting the boat and it did not want to start. I took the plugs out and noticed the bottom plug had a good bit of milky looking liquid. The middle plug had a little bit and the top plug just looked a little wet but pretty normal. Do you think it could just need the old gas removed and let the cylinders dry out? I am thinking that maybe it just took on some water in the tank and that is causing the milky looking liquid, which would keep it from firing. My other question is why would one cylinder have a lot more than the other two, unless the weight of the water is just sinking? Would a bad head gasket maybe be a culprit? I have never messed with a boat motor before and do not know where to start. Were these pretty good motors and is there anything else i should look for or check on it? Thanks for the help!!
Honorary Supreme Mariner
Look at head gasket ( compression test ) and the exhaust manifold gaskets.
jwolfe3
They were supposedly all
changed about 4 years ago, but it has not been ran much since then. He said head gasket and all 3 on the left side.
oldboat1
Look for 120psi plus, and even. Also good to make sure the fuel isn't contaminated (water).
jwolfe3
I will try the compression test tomorrow. What I’m getting out of the plug looks like it has water in with it. I’m going to drain the entire thing and put all New in it and run some sea foam throug it.
jwolfe3
So, going from top to bottom, I have pressures of 90, 100, and the bottom is 180. Should I just replace head and all exhaust gaskets?
Remove cylinder head for inspection.----Those numbers indicate trouble.
With compression numbers posted it should be obvious as to what is wrong.----Do not spend a penny on it till you take the head off !
