We have 69- 6HP Johnson that is hard to crank, rough idle, and when put in gear only speeds up to 1/4 - 1/2 speed (on the water).
1. When it does crank, seems like it runs out of fuel. Bulb is full of gas.
2. When idling (after adjusting carb) it's rough. It revs up and down on it's own.
3. Took it to the water - cranked after 20+ pulls. In gear, full open barely moving.
Rebuilt the carb. (soaked in carb cleaner overnight). Cannot buy new carb. Obsolete/discontinued.
New float (non-cork)
New plugs set at 0.30
Set points to 0.20.
Any suggestions on what else can be our problem?
Set points to 0.20.
