Re: Johnson 6HP Cylinder Head
Joe, Thanks for the clarification......I read this post thinking "bolts to the motor" and thought in broader terms....hence , the whole fuel pump. I guess is boils down to going just a little bit further in your thinking (mine actually!) when trying to give advise and sorting out a problem. So, again, I have learned something, have your mind in gear, think the entire problem through first, before you snap off a possible solution to a problem. It's truly a fine art of 'reading between the lines', and you are a master at it for sure. Thanks X
