Johnson 60 HP
wayland
Hi, I have 1987 Johnson 60 HP outboard no spark on all 3 spark plugs. Any help would be nice. Thanks
Bosunsmate
Try disconnecting the back wire with yellow stripe that feeds into the powerpack, thats the kill circuit
wayland
I tried that and still no spark on all 3 spark plugs. Any more suggestions? Thanks
emdsapmgr
It's unlikely all 3 coils failed at once, so you will be checking the stator, and timer base first. The CDI guide Bonsun mentions will have you check the cranking output of both devices. You will need a special "peak-reading" voltmeter to check the output. If both of these devices check ok, then it's likely the power pack. Engine to crank at least 250 rpm's to make proper ignition voltage output.
