johnson 6 hp outbard
pacemarker
l just change the impeller ,l was told not pumping water,had to put oil in cylender to run motor,where does the water comes out from the back of the motor. thanks
Elbo
Re: johnson 6 hp outbard
If ur not getting water in at least 1 min shut it off.At high throttle it will get hot very fast.
pacemarker
it is 1966 johnson 6hp seahorse out board motor
Elbo
I have a 1965 evinrude fisherman,Same motor and the tell tale is at the back of the leg just under the motor.If the impeller is good you should see a stream of water there
jasper60103
bktheking,
thats one sweet looking motor. Sounds great too. Good job! -jasper
bktheking
I wish, I don't speak "Verwendung an meinem Segelboot", I was just posting an example for him to see it pumping water.
