Pictures.... If not in the advanced editor, click on the large "A" to your right. That brings up the advanced editor..... Now, lay your cursor on the icons to your right until one says "Image". Click on that... the rest should be self explanatory.
I believe you must have at least three posts before you can post photos. So just post two more and you should be okay. What color is it? Does it have forward and reverse gears or does the power head turn around 360 degrees? Where is the throttle, on the tiller with a twist grip or on the motor?
