Johnson 55 1980 sneezing at idle
ondarvr
I have a 90hp Merc that had a bad sneeze when I bought it, when I first started fiddling with it it sneezed hard and blew the fuel line off the inline filter between the fuel pump and carbs. I had just checked the filter and hadn't put the clamps back on the fuel line because I was going to be taking it apart again in a few minutes.
The fuel pump was activated off the sneezing cylinder and it over pressurized the fuel pump.
mlaajanen
don't know any thing about reed valves, but had a lean sneeze once that blew core plug off my top carb, never did find it.
while carbs are off, gently poke a small hole in plug and pry it off, poke small wire through holes inside, new plugs come in carb kits or separately ( i like spares), put in place dome up, put a 3/8in. extension on it, give one good tap to cave in dome, and you set. do you have a service manual for you engine yet?
Hi. I have some kind of service manual that I got for $10 or so but it seams to be for all Johnsons not just the 55. Is there one specific you would recommend?
juno pierrat
Factory manuals are best of course, look online might find a free one, and of course this has them
mlaajanen
I have now tried to clean and clean and it looks so clean but still does not run well on the lower cyl.
Then I removed the idle jet and then it runs fine, a bit fat I guess but atleast I now are on the right track.
thanks everyone.
