Hey there,
Been having troubles with the outboard since the boat was put into the water this year. As the title states, get to anything more than 1/2 throttle and it'll start to bog out. Will start fine and idle properly.
Here's what's been done....
- tried 3 different fuel tanks and lines to the motor (one from a friends boat with a new primer bulb, which is definitely working properly) with no change in the problem.
- All fuel lines lines within the motor were removed, blown out and reinstalled. One line (from carb to carb) was replaced as it looked to have a tear in it.
- fuel filter screen cleaned out
- rubber gasket for fuel filter looks in good condition
- while running, tried pumping primer bulb with no change
- while running, tried pulling choke at full throttle with no change
- changed out the plugs with new ones
- new gas
- tried with gas tank cap cracked and screwed on tight
At a loss of what to try next, sure does seem like it's starving for gas ????
Does anyone have any tips as to where to go from here?
Thanks in advance!!
- new gas
Thanks in advance!!
