Nathan Hamilton
- Aug 28, 2010
- 7
I am in the process of building a boat and acquired a 1972 Johnson 50HP motor. The motor has been installed and was working properly. I had to use this technique to replace a faulty shift switch: http://forums.iboats.com/showthread.php?t=175907 , and it worked perfectly. However, after working on some other parts of the boat, I came back and tried to run the motor. Now, inserting the key and attempting to start does nothing at all.
I have followed these troubleshooting instructions: http://continuouswave.com/whaler/reference/electricStart.html . The motor passed the first test but failed the sixth. The guide suggests that this is a solenoid failure, but I don't see any reason why the solenoid would have failed since the last motor test (it's only been a week since it ran properly).
My guess is that the ignition switch might've failed based on a problem I had a couple of times when testing the motor earlier. The motor failed to turn off a couple of times upon turning the switch to the "Off" position and removing the key.
Is there a test I can perform to verify whether or not the switch is the problem, or am I going down the wrong path?
