johnson 50 hp shift throttle control
brian103181
Im brand new at this...bought a boat an old one with an old johnson 50hp on it..
I can not figure out the cables....
I need help...I am mechanically inclined being a mechanic...but i cant figre it out
if anyone know this setup it would be great if you can help....
right now the idle is high if i back the control up it goes down from middle...
it is always in forward gear... its cable throttle and shift
HighTrim
Re: johnson 50 hp shift throttle control
Could you post the year, or even better the model number?
brian103181
umm dont know...it has solenoid choke...off the key.....and it looks to be from the 80's
pduquette
Ensign
Welcome brian!
Check for a plate on the mounting bracket (see attached photo) it will give you model and serial number so we can help you better
HighTrim
That would be the serial number. We need a model number for the year. It will look something like J50ELCSA. If not on the stern plate as mentioned, look for the welch plug. It will be about the size of a quarter, and on the rear top of the motor. Could you also clarify what information you are looking for?
brian103181
that number is on the quarter sized metal round plate on the motor and is on the metal tag on the outside....it is the only numbers on my motor i searched for an hour
HighTrim
A picture may help if you could.
What cables are giving you trouble? What troubleshooting are you trying to do?
brian103181
the throttle cable and shift cable are easy to move ....
but I have no clue how to adjust the throttle with the shift at the motor......
I just want to know if there is a trick to it....should it be easy....
I tried just about everything......
it stays in forward.....I dont know where to start the adjustment....
any help will be awesome.......I have adjusted the to barrel threaded things both ways...... I just cant figure it out
brian103181
Im so sorry guys.....
The cover was off...
Its a 1980 something mercury 50hp.....Im a retard
HighTrim
The mods will move you to the merc forum, they should be able to guide you there, gl
