Johnson 50 hp 1983 shift lever
Chris860
I re-assembled a lower unit and it won't shift into Neutral? How do I know the shift lever is in correctly?
Chris860
I tried. This was apart when I got the motor. Do you know how long the shift rod should be?
Bosunsmate
Nope, ive a similar model.
So it goes into forward and reverse and no Neutral?
Have you tried unhooking the motor cable and trying by manually moving the lever
juno pierrat
long shaft 21 23/32 +/- 1/32, short shaft 15 29/32 +/- 1/32 from gear case to center of shift rod whole
Chris860
OK, I got the lower unit back on and into Neutral. I started the motor but when I shifted into reverse it stays in reverse. Any suggestions. The rod is not long enough for 21 23/32". It looks like its 20 21/32".
juno pierrat
remove lower unit again, measure from the top of the lower unit case , make sure its in neutral and turn shift shaft counter clock wise
