Johnson 50 Alarm
Fish929
Guys, I just got a "new" 2000 50HP Johnson 2-stroke and took it out last Saturday for the first time. I think there might be a short in the alarm because it kept going off.
For example, as soon as I put the boat in the water and turn the key one click, not even cranking it, it would go off; a continuous "beep." It also beeped randomly throughout the day. It was "peeing" perfectly normal the whole day and I was running the correct 50:1 ratio with Yamalube, so I don't know what's wrong with it.
Anybody had this problem? I don't want to disconnect it but I also can't have it beeping constantly.
Thanks
tashasdaddy
Re: Johnson 50 Alarm
when you turn the key there should be a quick beep, test beep.
J/E Alarms
low oil alarm is a beep every 30 seconds. beep......................beep...................
no oil alarm is a beep every 1/2 second or so.beep,beep,beep
overheat and fuel restriction alarm is a constant beep.beeeeeeeeeeeeeeeeeeeeeep
