Johnson 5.5 Hp CD-20 - No Spark
xavier56
Hello,
I have a Johnson 5.5 Hp CD-20 with No Spark. The Back Round is I got this motor not running and was started to be repaired by someone else. They installed Two New Coils, Condensers and Points. Could not tell if replaced the Spark Plug wires for sure- caps are new , the wires look in excellent condition. There is no Spark at all, not even a weak spark if you hold the plug and hand to the case. I have looked it all over and cannot find any issues. I have read the 1954-1964 Evinrude 5.5 HP Tune-UP Project Ignition System Tune-Up on another site. Looked at the pictures and tried to see if something was installed incorrect. Rechecked Gap was Ok. I cannot find what I am missing. Took picture and compared to the Tune up picture, do not see anything different. I could see one with no spark but not both. Any help would be appreciated.
Thank You
RCO
Double check that the points are at .020 with the rubbing block at the keyway on the cam (not where the cam says TOP). Make sure to clean the points with some clean paper dipped in acetone or lacquer thinner after they are gapped. Make sure the flywheel key isn't sheared.
oldboat1
If there's any doubt about the assembly, you might pull it apart and start over (would do one side at a time, if you take it apart). The points and condenser belonging to a coil are on the right of the coil. Can be the little things that make a difference -- spring connectors in the plug boots have to be in contact with the wire core (spike in contact with the core). If you are a multimeter guy, you can do a little testing without disassembling the magneto. Set the tester to RX1, and attach red wire to connector in boot, and the black end to the magneto plate. Should see a resistance reading of 5 or 6 -- main thing is that you see a reading, telling you there is a connection. Also make sure the coils are mounted perfectly flush with the mounting bosses. This sets the air gap between the coil and the rotating magnets in the flywheel.
xavier56
Thank you for the answers - I gaped it at the top point ( will try tomorrow at key) but as I understand how this works I still should get some spark maybe the timing would be off. The points are brand new and cleaned with clean paper will double check again tomorrow. The Key Looks good.
I did a quick test with VOM and had connection between the boot end and ground on both plugs. Checked the position of coils and looked good. This is why I cannot figure out what is going on. I have worked on this set up before on motors. It is like something is going to ground so do get any spark. Figure see if someone has any ideas what I am missing. Maybe need to take the whole thing apart and check all piece by piece.
If any one has any more ideas please send them. I am at a loss with this one so far. Thank you
oldboat1
Check magnet strength -- dangle a screwdriver in front of them. Failure is rare, but happens. I set the points when the rub arm contacts the highest point on the cam lobe.
How are you testing for spark? Set the tester for 1/4", and make sure it's got a clean, solid ground. Test with both plugs removed.
F_R
Rectifier??? There ain't any on a CD. The most common problem on a job like this is the points are not making good contact. Even new points have an invisible coating on them that must be removed.
OptsyEagle
I may be showing my ignorance on this but wouldn't a probe between the plug boot and ground show an open circuit. If one gets a "connection" would that not mean his ignition is shorting to ground instead of sparking like it should...or perhaps that is what he meant.
F_R
Nope, one VOM lead to the boot and the other to mag plate ground should show the combined resistance of boot terminal, wire, and secondary winding of the coil. Expect a few k-Ohms. Of course the coil's ground lead must be connected for this to work.
xavier56
Hello All
Thank you for the help - I dissembled the whole system and checked everything and put back together and now have spark.
Never found what it was and even got it running.
Thanks again
