Johnson 4R73c - New
PBoudreau
Hi, I have recently picked up a Johnson 4R73c that has never been used and is like new. Before I start this up, would there be any maintenance to do on the motor? I am also curious about the value of the motor in its new condition.
Thank you
kbait
Definitely change out impeller before you start it.
Honorary Supreme Mariner
Pop the flywheel off.-------Likely the coils are cracked and need to be replaced.
F_R
What are your intentions for this motor? Do you plan to use it? Or do you plan to preserve it? If it truly is unused and like new, and you want to preserve it (and its value), leave it alone. But if you plan to put it into use, then I agree, check the coils and replace the impeller. And any other items that may have degraded through simple aging, such as fuel lines. Speaking of which, the original lines probably are not Ethanol-proof.
PBoudreau
Thank you all for the information. I will replace the parts as you have mentioned. As for my intention, I bought this to use, but now that I have the motor and it is in pristine condition, I am debating whether to use it, or to preserve it.
Wall hangers do not need new parts.--------Just some wax.
