Johnson 4HP dies under load
dslance
I have a '85 Johnson 4hp, with an external tank, that idles fine but when I engaged the shift lever it dies after about 30 secs. I can then restart it after a few pulls but it will do it again. Sounds like a fuel flow issue. I've replaced the fuel pump and looking for where to look next. I'm wondering if I should look closely at the fuel tank and hoses or go after the carburetor? I recently overhauled the carb. Again it idles fine. Thanks
RCO
Make sure the tank is venting first, then try pumping the bulb in the fuel line while it is acting up. If it stays running you still have a pump issue. If that doesnt work, you will need to do a carb cleaning and kit.
Vic.S
Do as RCO suggests ( take the cap of fif there is any doubt about the tank vent)
You say you have replaced the fuel pump so pump problems are unlikely, as are carb problems if you overhauled it properly.. If you can keep it going by repeatedly pumping the primer bulb then check the fuel line for air in leakage , esp at the connector. The O ring in this may need renewing !. [h=2]O-RING: part number 0303598[/h] Check for the possibility that is is only running on one cylinder.
Do a compression test if you can beg, borrow or steal a tester from someone.
fhhuber
Found similar issue with a riding lawnmower... turned out to be a stick in the fuel line.
Check that there's nothing obstructing the fuel flow.
