Johnson 48 SPL suddenly quit while warming up
Wwaldron
OK, I've had this boat for a month or so and the motor has been running a little rough, but she started and ran every time. I bought a manual and replaced the coils about a few weeks ago and the idle smoothed out, readjusted the idle settings on carbs (lower was way too rich) and idle got smoother, plug color looks good and the world is looking brighter. I ran her around the lake 4 or 5 times after this with no issues. Last week I'm warming her up for a little cruise and after about 3 minutes at idle, she just stopped. No sputter, no cough, no smoke, no noise, she just died like the fuel had suddenly been cut off. I noticed a small amount of fuel leaking around the Schraeder valve on the primer solenoid/knob so I bought a repair kit and replaced that assembly today (shaft of red knob was cracked), but no joy- she will not start. Here are some specifics:
Same fuel and tank as before when she ran well
Same plugs as before and they look good
Cylinders/plugs are getting gas, plugs are wet
Plugs have spark and will ignite gas vapor as you roll the motor over (ask me how I know...)
Tank/bulb/fuel lines seems to prime fine and hold pressure
So, I seem to have fuel, air and spark, but I can not get her to even cough or catch, NOT even with a shot of starting fluid and THAT ain't right. It was 78 and sunny here today, so ambient temp is not an issue. It seems that it has to be electrical, but where to look? All fuses that I see appear to be good as are all connections.New coil gone bad? Timing? And if so, wouldn't it at least cough and sneeze at me a little? I'm obviously missing something and its probably something obvious. Help!
Thanks!
ondarvr
I had a similar thing happen, idling in the driveway and just stopped, never to start again. Had compression, spark and gas, turned out to be a sheared flywheel key.
jakedaawg
Well, start at the beginning...Compression check, open air gap spark test (holding the plug to the block tells you nothing), fuel sample....
oldboat1
I would do a proper spark test first. If consistently good spark, check compression (maybe failed head gasket).
Think sudden changes, particularly related to prior fixes: sheared or partially sheared flywheel key is something to consider, as above -- can result from inadequate torque when you reassembled. Try turning the flywheel by hand and see if you feel compression. Whatever you find, would pull the flywheel and check or replace key, then inspect prior ignition fixes -- look for wire abrasion, and make sure components are in place and tight. No screws missing.
Reassemble and test/retest for spark with a tester.
F_R
Honorary Supreme Mariner
Getting a shock from the plug wires is not a spark test. If that system is working right, it will knock you right out of your shorts. I also am guessing flywheel key. But that is just a good guess. You will have to do some troubleshooting.
Wwaldron
Solution found. It was the brand-new CDI coil that I had installed approximately 1 week prior. The motor ran great for a week and then just stopped while warming up. I guess when the coil failed the resulting spark it produced was too weak to provide ignition. After I had looked at everything else (and replaced a lot of it) I finally put the old coil back on and it fired right up. Swapped out the old coil with the new coil and she would not run. Reinstalled the old coil just to verify and she took right off. Now I have to see if I can get a replacement coil.
sutor623
So next time you will use a spark gap tester to verify spark on all cylinders right? :)
Glad you figured it out, and thanks for the resolve.
