Maverick49
- Jun 4, 2007
- 28
I have a 1990 40hp Johnson, I get a constant warning horn buzz with with the key on, I was told the horns do go bad, also to check the pee hose to see if it's shooting water and if it's hot to the touch, and to also see if I could put my hand on the cylinder head and not get burned, So I changed the warning horn to a new one, and still I get the buzz with the key on, and the water coming out of the pee hose is cold, and I can put my hand on the head and not get burned but it is very warm, so I took out the temp switch and have tested it according to my OMC manual page 4-7 and the switch opens up about 180 degrees but will not close even when the temp of the oil gets up to 230 degrees, the book says the switch must react to the changing temperature and to replace the switch if my results vary. Do I need a new temp switch?
