Hello, i have recently become the proud owner of a 1970 crestliner equiped with a 40hp electric start johnson outboard motor of the same year which i am hoping to restore. The hull and overall condition of the boat are in fantastic shape given the age of this beauty, however, i have thus far been unable to get the motor to run. The unit is able to start up via the igntion but stalls almost immediately thereafter. Initially the switch that makes contact with what i am assuming is the stop/shift lock, based on imagery, was coming lose from the body and breaking the connection effectively killing any means of ignition via the key, some loctite on the bolt that threads into the body to hold its bracket in place seems to have taken care of this issue. The solenoid have been replaced, spark plug replaced and gap set, carb cleaned as per a local mechanic whos work is a little dodgy at best given his lack of knowledge on older motors (the motor happens to be twice his age), and thus i am left trying to figure out what is going on myself. I have a fair amount of mechanical knowledge but outboard motors is a very new thing to me and any advice regarding this issue would be greatly appreciated. Thank you.
P.S. I have recently come to the knowledge that the fuel/oil mix is 50:1 and is best used with octane 87, i am unsure of the current mixture which is possibly 60:1 so i will be trying this out at the next opportunity i have to work on the motor.
