Johnson 40E74S outboard wiring
Wentiphus
Hello!
Recently I have bought a Johnson 40E74S 2 stroke 40 HP 2 cylinder outboard. The motor has electric start. Problem is that the Solenoid does forward th batery+ to the strarter, so it is either broken or not wired right. When directly connecting the battery + to the starting engine it immediately starts running. Before a few times it did let through the + to the starter. Furthermore the closeby fuse is good.
I am under the impression that the neutral safety switch is not connected well, I can see it is only wired with a + so not with other wires. Any advice is very welcome. If anybody would have a wiring diagram could you send it please?
thanks in advance.
regards Jan
Honorary Supreme Mariner
There is only one wire to the " nuetral / too much throttle " switch.------Take that wire and have an assistant hold that wire to ground.-----Will the motor now crank with the key ?
Wentiphus
It seems the motor has 2 safety switches, one to protect for starting with too much throttle and one for starting when in gear instead of neutral. Both now only have one wire.
Should I then ground both of these safety switches?
Ground both and see if it will crank.------------After that test you might determine which switch is bad.---------I clean the inside of these switches although some will always say " can not be done " as they are riveted !---------Fact is they are easy to take apart for cleaning !
Wentiphus
Thank you racerone for your advice. I will connect both switches to the - and I will try to clean them.
What surprised me is that these switches only have one wire each, should that not always be 2 each?
A wiring diagram to check all wiring could be very usefull allthoug I did not add, remove or change any wired connections.
No surprize at all.----These switches just complete the circuit to ground.-----One wire is all that is needed !!
Wentiphus
Ok I have tried and the cause is different. Situation is now that when starting with the key, it sometimes takes up to 30 seconds before the starter kicks in. Wires connected to the key ifnition become hot. So probably wiring is weak/not connection well.
I will try to walk through and follow all wires. Any advice for weak spots perhaps/where to look?
Thanks!!
Wentiphus
Wiring at engine entrance was not connecting 100%, its replaced and now motor starts directly, wires at key ignition side are not becoming hot anymore either. Thanks!
