scurvydawg
Thread starter- Joined
- Aug 8, 2003
- 1
Johnson 40 VRO W/ t&t early 90's: Recently, while running fine we ran out of gas, changed tanks, and restarted. It ran for a minute or two, sputtered and died dead as a hammer. No response from key switch, no elec. tilt/trim response, etc. Other electronics still worked. Have 12V between battery and coil. I suspect the switch and throttle control area. Any suggestion or info on how to disassemble the binnacle? Am I completely off track?<br /><br />Also, on the binnacle there is a black knob facing aft that will turn, it looks like a fuse holder but doesn't unscrew -whats that? <br />There is also a triple prong plug facing aft with a single small ga. wire (other 2 holes are plugged) -whats that?
