Slowfaller
Thread starter- Joined
- Sep 7, 2016
- 2
Hi all, just wanna preface this that I'm new to outboards entirely surprise surprise
I ordered a replacement water pump kit for my 1978 Johnson 35hp outboard and noticed the new impeller is too small for the housing and the metal plate and gaskets do not line up with my current water pump housing. After some more research on parts, I see that my outboard actually has a 1977 water pump housing/impeller etc and the 77 doesn't use any gaskets. Also, the 77 impeller is longer than what I received for my model 35r78r.
The motor was bought used and when I took the LU off I saw someone at some time used JB Weld Red high temp gasket maker to form gaskets on the bottom of the metal plate and the bottom of the housing.
The 77 and 78 water pumps are definitely different according to parts lists so Im confused on what to do. The old water pump did work and I've used the outboard several times this year with no over heating issues until the impeller broke and the spacer tube partially melted. Is it possible I have a 77 lower unit in a 78 motor?
Can I clean up all the parts and use the longer impeller that I later ordered (along with some 3 hole housing that is useless to me)? I dunno how this is even possible
Thanks,
Chris
Thanks,
Chris
