Johnson 35hp - 78 Mod - power pack, reed valve questions
PiperBill
Hi all.<br /><br />My first post to this forum. I live in Norway.<br /><br />I have a Johnson 35hp, manual start outbourd from 1978. Details as follow:<br /><br />Model # 35BA78R<br />Serial # B6321<br /><br />Question 1:<br />I looking to replacing the power pack. Can anyone point me in the direction of a supplier in the USA? <br /><br />Question #2<br />What symptoms would a defect, worn reed valve plate assembly have on above motor.<br /><br />Qustion 3:<br />Last time out on the fjords I had an engine failure with the above motor. I got it started after ages of pulling the hand starter but it ran terribly rough and there was some backfiring that neally pulled my arm off. It ran only for a minute or so and when I put it into forwad gear the boat went backwards. In reverse it moved forward. Is it possble for a motor to backfire and run in reverse rotation? It's now running as normal, although still a bit rouhg.<br /><br />Many thanks<br /><br />Bill Carr<br />Oslo - Norway (originally from Sydney Australia)
JB
Re: Johnson 35hp - 78 Mod - power pack, reed valve questions
Hi, Bill.<br /><br />Sounds like your flywheel has sheared its key and thrown the timing way off.<br /><br />A defective reed or reed plate gasket would cause a dramatic loss of power in the affected cylinder and a spray of fuel mix out of the carb throat.<br /><br />Good luck. :)
